Window removal
shakajava
PostPosted: Sat Jun 27, 2009 8:57 am    Post subject: Window removal Reply with quote
Can you remove a window the same way you can install a window with string or ????
I know you can just cut them out. But, I have the windows in new rubber and would like to keep them if I could.
69' Beetle CA Look 1500SP
71' Super 1600DP
skeeter
PostPosted: Sun Jun 28, 2009 11:56 pm    Post subject: Reply with quote
I don't know about string. I've always used a screw driver I sand all the sharp edges off and slowly work my way around the seal.
PostPosted: Mon Jun 29, 2009 7:38 am    Post subject: Reply with quote
out, you can use small picks, and slowly work one edge off, while pushing out. once you get the second edge, it will start to pop out.
shakajava
PostPosted: Thu Jul 02, 2009 10:49 am    Post subject: Reply with quote
Thanks for the information. I want to get the windows out so I can finish getting the shell ready to paint.
71' Super 1600DP
shakajava
PostPosted: Fri Jul 03, 2009 2:02 pm    Post subject: Reply with quote
Thanks for the tips! I was able to get the windows out and saved the rubber. I started working the gasket in middle of the top of the window. Worked my way around the edge until I was at the bottem and out popped the window. Thanks again!
Now I just have to figure out how to get them back in.
71' Super 1600DP
neanders
PostPosted: Fri Jul 03, 2009 5:20 pm    Post subject: Reply with quote
Getting them in is easier than getting them out! I've got to do my front and rear windshields at some point, I'll help your if you help me!
It's mine now, and I want a BAJA!!!
shakajava
PostPosted: Fri Jul 03, 2009 5:33 pm    Post subject: Reply with quote
No problem. Let me know when you want them out. It does take very long to extract them.
71' Super 1600DP
