shakajava
Posted: Sat Jun 27, 2009 8:57 am Post subject: Window removal |
Can you remove a window the same way you can install a window with string or ????
I know you can just cut them out. But, I have the windows in new rubber and would like to keep them if I could. _________________ 69' Beetle CA Look 1500SP
71' Super 1600DP |
skeeter
Posted: Sun Jun 28, 2009 11:56 pm Post subject: |
I don't know about string. I've always used a screw driver I sand all the sharp edges off and slowly work my way around the seal. |
Posted: Mon Jun 29, 2009 7:38 am Post subject: |
out, you can use small picks, and slowly work one edge off, while pushing out. once you get the second edge, it will start to pop out. |
shakajava
Posted: Thu Jul 02, 2009 10:49 am Post subject: |
Thanks for the information. I want to get the windows out so I can finish getting the shell ready to paint. _________________ 69' Beetle CA Look 1500SP
71' Super 1600DP |
shakajava
Posted: Fri Jul 03, 2009 2:02 pm Post subject: |
Thanks for the tips! I was able to get the windows out and saved the rubber. I started working the gasket in middle of the top of the window. Worked my way around the edge until I was at the bottem and out popped the window. Thanks again!
Now I just have to figure out how to get them back in. _________________ 69' Beetle CA Look 1500SP
71' Super 1600DP |
neanders
Posted: Fri Jul 03, 2009 5:20 pm Post subject: |
Getting them in is easier than getting them out! I've got to do my front and rear windshields at some point, I'll help your if you help me! _________________ It's mine now, and I want a BAJA!!! |
shakajava
Posted: Fri Jul 03, 2009 5:33 pm Post subject: |
No problem. Let me know when you want them out. It does take very long to extract them. _________________ 69' Beetle CA Look 1500SP
71' Super 1600DP |
