'56 Custom Project
jestes
PostPosted: Thu Oct 04, 2007 10:20 pm    Post subject: '56 Custom Project Reply with quote
'56 Custom Project
This is a body that I rescued from a now closed wrecking yard in Seattle back in 1992. It was hit so hard in the passenger rear quarter that the car was rolled up on the driver side and the rain gutter was crushed.
 Filesize:  70.81 KB
 Viewed:  19301 Time(s)
There's a ton of filler in that quarter!
 Filesize:  73.31 KB
Jason Estes
Oval Bug - 56/69
http://57bugbuild.blogspot.com/
jestes
PostPosted: Thu Oct 04, 2007 10:24 pm    Post subject: Reply with quote
'56 Custom Project
First thing to do is fix the inside of the quarter. This was some sloppy work, but what do you expect from an 18 year old?
 Filesize:  75.37 KB
 Viewed:  19299 Time(s)
Here you see the old metal all cut out.
 Filesize:  83.82 KB
The new piece is all welded in!
 Filesize:  57.55 KB
Jason Estes
Oval Bug - 56/69
jestes
PostPosted: Thu Oct 04, 2007 10:34 pm    Post subject: Reply with quote
'56 Custom Project
I got the quarter cut out and found a bunch of rust behind it. The car sat with no windows in the wrecking yard for a few years.
 Filesize:  84.87 KB
 Viewed:  19298 Time(s)
The majority of the rust has all be blasted away. It's gonna take some work to replace the soft metal though.
 Filesize:  64.46 KB
The outside portion of the heater channel is finished. I still need to do some work from the back. But I have to pull the body off the pan for that.
 Filesize:  64.42 KB
Jason Estes
Oval Bug - 56/69
jestes
PostPosted: Thu Oct 04, 2007 10:38 pm    Post subject: Reply with quote
'56 Custom Project
The inside is almost finished. You can see a few pin holes in the bottom of the B-post that still need some work.
 Filesize:  54.98 KB
 Viewed:  19297 Time(s)
The top side of the passenger heater channel is all finished.
 Filesize:  59.52 KB
Jason Estes
Oval Bug - 56/69
ovalback_vw
PostPosted: Fri Oct 05, 2007 5:07 am    Post subject: Reply with quote
Very nice job, a very sweet oval, be proud of it, be very proud-------chris Arrow Arrow Cool Cool Cool
PostPosted: Sat Oct 06, 2007 8:57 pm    Post subject: Reply with quote
Another Oval back to the street, just do the car a favour and ditch those poor front fenders
What year pan?
Jeronimo Villalta
PostPosted: Sat Nov 24, 2007 9:14 am    Post subject: Thanks Reply with quote
thanks for the pic......wow
PostPosted: Sat Nov 24, 2007 9:34 am    Post subject: Reply with quote
Which yard? Brian's?
jestes
PostPosted: Sun Mar 23, 2008 11:40 pm    Post subject: Reply with quote
What year pan?
I like the front fenders, I think they turned out quite well. The pan is a '69.
Jason Estes
Oval Bug - 56/69
jestes
PostPosted: Sun Mar 23, 2008 11:43 pm    Post subject: Reply with quote
I think the place was called Alsop. It was in Everett not far off I-5.
Jason Estes
Oval Bug - 56/69
dean
PostPosted: Tue Mar 25, 2008 5:50 pm    Post subject: Reply with quote
Nice ride! Wink
jestes
PostPosted: Mon Oct 06, 2008 11:57 pm    Post subject: Reply with quote
'56 Custom Project - Finally back at it!
As you can see, the new quarter skin has been cut and tacked in place.
 Filesize:  102.68 KB
 Viewed:  17518 Time(s)
There is still some work to do on the back edge where the deck lid meets the fender. After that is cut and tacked in, I need to get a piece for the bottom of the quarter and rebuild the door jam.
 Filesize:  72.96 KB
Jason Estes
Oval Bug - 56/69
PostPosted: Tue Oct 07, 2008 7:37 am    Post subject: Reply with quote
Do me a favour, don't call everett Seattle ever again. It's like calling deer park Spokane. Silly willy
But your doing great with the car.....rust repair is never fun.
PostPosted: Tue Oct 07, 2008 12:05 pm    Post subject: Reply with quote
Nice work looks good!
jestes
PostPosted: Sat Oct 11, 2008 2:50 pm    Post subject: Reply with quote
'56 Custom Project
The entire quarter has now been replaced and everything is tacked in. All that's left is final welding and a ton of grinding.
 Filesize:  229.41 KB
 Viewed:  17460 Time(s)
The top edge of the quarter has been rebuilt. Everything is tacked into place and will be welded soon.
 Filesize:  237.3 KB
Jason Estes
Oval Bug - 56/69
