1965 VW 13W Deluxe
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Sun Aug 12, 2012 3:59 pm    Post subject: Reply with quote
No worries..........I used it on everything and was very happy. The stuff is tough and I like the fact you can put it on any way you want. Just thought it might be an option and save you some $. Keep the pics coming.
PostPosted: Sat Sep 08, 2012 8:31 pm    Post subject: Reply with quote
Been putting some time in on the bus. Making some progress. Here are a couple pics.
Some rust in the right dog leg.
Rust cut out, ready for a patch.
Back side
Patch installed
Same thing on the right side. Here is the right side complete.
PostPosted: Thu Oct 11, 2012 8:20 pm    Post subject: Reply with quote
Some work completed on the cargo rocker area. The cargo floor edge wasnt terrible, but had some rust through.
Hopefully, get the outer rocker in tomorrow.
PostPosted: Sun Oct 14, 2012 4:29 pm    Post subject: Reply with quote
I was able to get some free time today and got a little more work done on the bus. I've been trying to atleast put an hour a day into the bus. Usually when I get out to the garage and start working I end up putting more time in than my hour Very Happy
I'm pretty close to applying POR-15 to the bottom of the bus. I have a couple things that I need to finish up before that happens. One of which is the cargo rocker.
Cleaned up the inner rocker
POR-15 on the inner rocker. I also scuffed up the outer rocker and applied POR-15
Rocker welded in.
Tried to get my gaps as close as possible. Easier said than done!! After some tweeking of the Wolfsburg West outer rocker and some cutting here and there....
troyw1970
PostPosted: Sun Oct 21, 2012 7:15 pm    Post subject: Reply with quote
very nice work
are you useing gas for your welder or flux core wire? i just got my welder and am not using gas or flex core wire and my welds dont look that nice iam still practiceing
PostPosted: Sun Oct 21, 2012 7:19 pm    Post subject: Reply with quote
I'm using gas. Flux core is too messy in my opinion.
Did you mean to say that your not using gas OR Flux wire? You need to use one or the other or you welds won't be shielded and will be contaminated. If that is the case-they will always look bad.
troyw1970
PostPosted: Sun Oct 21, 2012 7:37 pm    Post subject: Reply with quote
yes i dont have ethere going to pick up some flux core in the morning
i am very new to welding started last week and i have lots to do on my 65 bug just need to practice more[img][/img]
PostPosted: Sun Oct 21, 2012 8:43 pm    Post subject: Reply with quote
From Suncrest--you're about 10 min from me. I'm on 5-mile.
I would personally get a bottle and use gas if your welder is set up for it. Unless its a $$ deal. The flux wire is pretty messy and requires a lot more cleaning up than gas welding. Welding thinner metal is also more difficult with flux shielded wire if I recall. More experienced welders would know better. Im just starting out as well. I'm no expert by any means.
PostPosted: Wed Nov 07, 2012 6:05 pm    Post subject: Reply with quote
Been keeping busy on the bus.
Finally got a little help!!!
We usually don't get a lot done when she comes out to "help" but it is sure fun!
PostPosted: Sun Nov 25, 2012 8:18 pm    Post subject: Reply with quote
I was able to finish up sandblasting the bottom and laying down some primer.
Here it is all sandblasted
Finally put down some primer. I am using the Master Series primer and going to topcoat it with the Master Series AG 111.
In primer
Hopefully Tuesday morning I will be able to topcoat.
PostPosted: Mon Nov 26, 2012 10:04 am    Post subject: Reply with quote
nice duke! you could eat off of the underside of your bus now its so clean. keep the work going so we can hopefully see you cruisin it next summer.
PostPosted: Mon Nov 26, 2012 10:57 am    Post subject: Reply with quote
Thanks Dan. Hopefully tomorrow put down some paint over the primer.
Trying to get the bus on wheels before the new year. However, there is a lot of work before that can be done.
PostPosted: Thu Nov 29, 2012 9:52 am    Post subject: Reply with quote
That looks great!!!!!!!!!!!!!!
PostPosted: Thu Nov 29, 2012 9:03 pm    Post subject: Reply with quote
Was able to install the heater tube. I also painted the bottom! Using my Iphone in poor lighting--sorry.
PostPosted: Sun Dec 02, 2012 7:22 pm    Post subject: Reply with quote
Doodoob wrote:
Looking awesome! Check out this stuff........ http://www.thesamba.com/vw/classifieds/detail.php?id=396637
http://www.masterseriesct.com/
I used it on my bug and really liked it. Seemed to be a little cheaper than Por15 and works great. I simply brushed/rolled/and sponged it on.
I ended up going with the Master Series. I used the POR15 on a couple little things and really didnt like the way it turned out. I really liked the Master Series and will use it again. Thanks for the suggestion.
Page 2 of 4
