Sump stud snapped! Now What?
numberdevil
PostPosted: Mon Oct 10, 2011 8:38 pm    Post subject: Sump stud snapped! Now What? Reply with quote
when putting nuts back on after draining oil, one of the ends of the sump plate studs broke off. I had some trouble getting the nut off initially, but thought it was due to dirt or whatever in the threads. Cleaned them all off prior to putting it all back in. Four of the nuts hand tightened just fine, with two having a bit of trouble. I was able to get one of them on okay, but not the last. Sad
I didn't put that much pressure on it at all, using my off hand, small socket held at the head of the wrench.
I'd say maybe a quarter inch snapped off. With the strainer and plate in/on, there is almost enough of the stud that the nut could fit on it.
I believe it is the stud that is attached to the pick up tube.
Any suggestions?
Thanks!
Nicole
First was 72 Bug
Now 69 Bug
PostPosted: Tue Oct 11, 2011 6:26 am    Post subject: Reply with quote
Easy fix...use some vice grips and back the stud out, go easy and clamp the vice grips down tight. If you have enough of the stud showing, you can use 2 nuts to remove the stud (sounds like you don't though). You can easily install the new stud (or temporarily use a bolt) with the 2 nut method again.
The stud is not attached to the pick-up tube...Those cap nuts don't take much torque at all...going from memory here cause I haven't looked in awhile, I think maybe 7 ft.lbs rings a bell?
PostPosted: Tue Oct 11, 2011 4:05 pm    Post subject: Reply with quote
Uhhh, No.
One of the studs DOES hold the oil pickup tube. It won't come loose except by unscrewing the nut with a right angle open end. I frequently replace that stud with a bolt when the engine is apart, if that's the case, you really have a problem. Try to get a look up in there with a little mirror to see what's going on. In the meantime, you can leave 1 nut missing and put a blob of silicone to keep it from leaking.
numberdevil
PostPosted: Tue Oct 11, 2011 8:41 pm    Post subject: Reply with quote
Thanks for the info.
I'm fairly certain that it is the one that is connected to the pick up tube, as the bolt head (or whatever is up there) feels different/larger than the others.
I will look up there with a mirror next chance I get.
Can it be taken out and replaced if I had a right angle open end? Or is this a major ordeal?
Nicole
First was 72 Bug
Now 69 Bug
PostPosted: Wed Oct 12, 2011 7:54 am    Post subject: Reply with quote
If it's a stud with a nut, you need to bend a 10mm wrench at a right angle so you can unscrew the nut, then you can turn out the stud just like the others.
It is a pain in the a$$.
numberdevil
PostPosted: Wed Oct 12, 2011 8:49 pm    Post subject: Reply with quote
*sigh* Tell me what isn't a pain in my A$$ these days ...
Will give it a go.
First was 72 Bug
Now 69 Bug
numberdevil
PostPosted: Sat Oct 15, 2011 9:07 pm    Post subject: Reply with quote
Today I was able to get a picture of this broken sump stud.
It looks like this is a bolt (and the one on the left as well) but is rising higher than the others. it is 10 mm.
Is this what it is supposed to look like?
First was 72 Bug
Now 69 Bug
PostPosted: Sun Oct 16, 2011 7:03 am    Post subject: Reply with quote
Whoa, Whoa, Whoa.
You have an aftermarket deep sump on there.. So unscrew the 6 nuts that hold it to the actual engine block, and then replace the bolt. Bolt it back on with a paper gasket and some sealer.
numberdevil
PostPosted: Sun Oct 16, 2011 1:30 pm    Post subject: Reply with quote
Yes, I knew that it was an after market sump all along ... but stupid me didn't mention it. sorry, sorry, sorry. Embarassed
Thanks for the advice!
nicole
First was 72 Bug
Now 69 Bug
numberdevil
PostPosted: Sun Oct 23, 2011 2:25 pm    Post subject: Reply with quote
Was able to back the bolt out, and replace with a stud.
way easier than I thought.
*whew*
First was 72 Bug
Now 69 Bug
