Bad Bug Two
Posted: Wed Jun 22, 2011 7:18 am Post subject: Closer! |
Man time flies, not only when you're having fun, but even when you're not!
Any case, I did a little tuning over the last week with the nitrous and l am going to finally finish the transaxle this weekend. Once I finish a couple other loose ends on the car, hopefully I will get it out to the track in a couple of weeks.
By the way, with a little bit of nitrous I put down 348 hp and 288 ft/lbs of torque. That tune should be good for high 9's in the quarter and once I make a few more upgrades I will try the bigger nitrous jets!  _________________ Jeff Rogers
www.badbugracing.com
9.35 @ 145 |
