Posted: Sun May 15, 2011 4:21 pm Post subject: Motor rebuild questions |
Alright I'm looking for some help I have a type 3 short block I want to rebuild for a back up for either my square or bus. Basically it came with 4 pistons in it but only 2 had cylinders no flywheel or pulley. I pulled the 2 cylinders of and put a pulley on the front and it turns free and smooth. The thrust bearing doesn't have any play in it either. Now the inside is kinda dirty looking probably cause it was sitting with out 2 cylinders for a while. I'm wondering how to tell the condition of the insides i.e. crank, cam and rods. Or where would be a good place to take it to have it checked out? |
Posted: Mon May 16, 2011 11:19 pm Post subject: |
Well I think I'm going to try and just slap some new piston and cylinders on it and see if it will work for a good back up motor I guess well see. |
Posted: Tue May 17, 2011 6:42 am Post subject: |
Don't put it back together without taking it all the way apart. Any dirt will ruin it immediately. Besides, you need to know what's what inside. The only special tool you need might be an air gun to get the flywheel nut off. I can do that for you. Mark where all the part came from, especially the lifters. Use a paint pen, or make a cardboard thing to hold them.
You can find all the information you need on the samba. |
Posted: Tue May 17, 2011 7:09 am Post subject: |
Ok if I take it apart and all pieces look good will I then have to get any machine work done to the block to be able to put it back together? Or will I be able to just clean it put it back together and use it? |
Posted: Tue May 17, 2011 11:10 am Post subject: |
IF everything is good, which is unlikely, all you need is a gasket set and main seal. |
Posted: Tue May 17, 2011 4:57 pm Post subject: |
I like the IF....I've never pulled a motor apart (Chevy or VW) that didn't need something. You can definately "slap" engines together...but you'll most definately be pulling it back apart REALLY soon. Most often due to catostrophic engine failure....in the 80-90's I didn't care....but now, even machine shops are having difficulty finding good core 1600 cases....
