Looking for '63 turn signal assembly.
Kylees63
PostPosted: Thu May 03, 2007 6:22 am    Post subject: Looking for '63 turn signal assembly. Reply with quote
Looking for '63 turn signal assembly and a 6 volt turn signal resistor as well. Have lots to trade or will buy.
Alse looking for drop spindles and/or narrowed beam for same.
Kevin
509-590-8335
PostPosted: Fri May 04, 2007 9:38 pm    Post subject: Reply with quote
You can hook up with Franklin
Franklinsvwwerks.com.
We have a forum as well.
(this is primarily for the beam etc...)
Kylees63
PostPosted: Sun May 06, 2007 3:00 pm    Post subject: Nice Reply with quote
Nice website, wheres this place at? Thanks
PostPosted: Tue May 08, 2007 5:01 pm    Post subject: Reply with quote
Franklin just moved his shop back to Kent
PostPosted: Fri May 18, 2007 7:56 am    Post subject: Reply with quote
did he? he didn't tell me....... thought he was doin fine at home in graham. Franklins a good guy, I miss his old shop.
You can try BRAX too.
PostPosted: Sun May 20, 2007 7:06 pm    Post subject: Reply with quote
They only moved because they wanted to be more central than Graham...people North were complaining Laughing
You should see the new shop Shocked two stories
PostPosted: Mon May 21, 2007 8:18 am    Post subject: Reply with quote
man...sooo many changes since I left Seattle.
PostPosted: Sat Jun 02, 2007 10:48 pm    Post subject: Reply with quote
yo i found the part
 Filesize:  252.88 KB
 Viewed:  9335 Time(s)
is this what you needed?
 Filesize:  277.21 KB
 Viewed:  9337 Time(s)
