Dale and Matt's vws
PostPosted: Thu Mar 11, 2010 9:45 am    Post subject: Dale and Matt's vws Reply with quote
After reading a lot on the samba I found that we really don't need to remove the fenders from the 70 bug for Matt and I's pan swap. Both pans have issues with rust under the back seat but that really doesn't bother us. I hope this posting of pics works.[img]http://www.rcvwclub.org/phpBB2/album_pic.php?pic_id=162[img][/img]
 Filesize:  117.69 KB
 Viewed:  10183 Time(s)
 Filesize:  108.15 KB
 Filesize:  73.29 KB
hakunamatata
PostPosted: Thu Mar 11, 2010 9:50 am    Post subject: Reply with quote
ok some more pics. Matt will retain the wood steering wheel and shift know. I retain the lil green monster on my customized shifter.
 Filesize:  116.16 KB
 Viewed:  10181 Time(s)
 Filesize:  113.05 KB
 Filesize:  67.94 KB
hakunamatata
Motelcambodia
PostPosted: Thu Mar 11, 2010 6:18 pm    Post subject: Reply with quote
Are they goinmg to be baja's?
Im all ways ready to go off roading look me up if your going any place
Brian
Work In Idaho Live in cambodia
PostPosted: Thu Mar 11, 2010 6:59 pm    Post subject: Reply with quote
Matt wants to go classic at this time but mine will be a class 11 clone. and yeah, I'm looking forward to wheeling with you and Neil in his jumping spider baja.
hakunamatata
PostPosted: Tue Jul 27, 2010 7:23 am    Post subject: Reply with quote
It's been a long time since first posting this. The green body is on my pan all bolted up. racing seats (thanks Neil), 1600dp (again thanks), had to cut the rar apron off to fix it, and it just makes putting the motor in easier. I plann to route my mufflers to exit in front of the rear tires (30x9.5x15). everything is done to get it running. had to replace starter switch. wil need a new fuel pump. I need to bleed the brakes,( made my own pressure bleeder. polished the steering column. don't worry I will post more pics later.
hakunamatata
PostPosted: Fri Oct 15, 2010 7:33 am    Post subject: Reply with quote
brakes adjusted. it gives you a penny or two change. 95% finished with the new seating arangement. (need to borrow Neil and his welder).
decided to go more street. this weekend I'll be breaking down my 30x950's to install some 205's
figured out a way for me to have tones without being afraid someone's going to break into it. (my house has been hit 4 times in the last 4 yrs) Mad
Heat works great Rolling Eyes uhm well i guess that's it for now.
hakunamatata
