Toph
Joined: 24 Oct 2009 Posts: 65 Location: Coeur d' alene
Posted: Sun Nov 08, 2009 11:33 am Post subject: Speedometer 66 bug |
My speedometer in my 66 beetle jumps around. It has plenty of grease in the wheel. Is ther a certain position the cable needs to be in to work correctely? I have tried different positions and it either gets better or worse. However I can not correct the jumping. Is there away to test the speedometer to see if its good? |
smithe
Posted: Sun Nov 08, 2009 11:57 am Post subject: |
Did you check the end that goes into the center of the wheel? I had a car that bounced around and sorta worked, turned out the little piece on the end of the cable was damaged and wasn't always turning correctly. |
Toph
Posted: Sun Nov 08, 2009 12:31 pm Post subject: 66 Speedo |
I will check that. I had the wheel off and it extends right into the grease cap and was pinned. it seemed to be turning. |
Posted: Sun Nov 08, 2009 2:37 pm Post subject: |
What condition is the cable and dust cap in? |
69 Jim
Joined: 02 Jun 2007 Posts: 13 Location: Nine Mile Falls
Posted: Mon Nov 09, 2009 12:21 pm Post subject: |
I just restored mine for cosmetic reasons, and found it still jumped a bit until I replaced the cable. Works very smooth now. Good luck. |
Toph
Posted: Mon Nov 09, 2009 9:59 pm Post subject: |
The cable seems to be in ok shape. Maybe I should just try a new cable and see what happens. What do you think? |
Posted: Tue Nov 10, 2009 7:51 am Post subject: |
I would try it out. Unless you pulled the entire cable out and looked at every bit of it; I would expect there to be alittle freying at some point causing the wack-o behaviour. |
