dillwad
Posted: Wed Nov 10, 2004 12:32 pm Post subject: new guy |
New here picked up a 86 GTI it has a few problems got some questions as to how the front struts act . or how they look when car is jacked up.
The P.O. had screwed up alot of wires. also removed the 02 sensor so i am sowly going thru it bit by bit hope to see some of you at next years autocross events.
Thanks in advance
lance |
Posted: Wed Nov 10, 2004 5:40 pm Post subject: new guy |
Hi Lance , welcome , there is a meeting tonight at 7pm if you can make it (map on meeting link) , if you haven't yet , you might also check out the autocross club website at www.autosportsnorthwest.org . Not real clear on what you mean about wheels when jacked up ? TROY |
dillwad
Posted: Thu Nov 11, 2004 6:34 am Post subject: |
HI Troy just got the message so i missed the meeting.
What happens is when i jack the car up , both front struts drop down ( viewing from the engine compartment ) they onlt drop as far as the collar on the top of the struts allow. I have had a few cars with struts and have never seen this before I have allready replaced both strut bearings as the were both shot. i just dont know if this is a normal volkswagen thing or not. everything seems to be in place.
thanks for the reply |
Posted: Thu Nov 11, 2004 5:11 pm Post subject: new guy |
I would suggest bad strut bearings , but since you did that already , I will have to jack ours up this weekend and see if it does the same thing . You could go out on Trent to see Brian at Snechentempo (891-5752) and ask him , he mainly works on watercooled VW's . TROY |
