mpgauto
Posted: Tue Jan 27, 2009 8:10 am Post subject: Rebuilt 5 Speed VW Transmissions |
Just thought I would let you know we're in the state of Washington so if you or someone you know is looking for a VW trans we're the place to go.
This is all we do!!!
Here is the general information regarding our products and service.
Fully rebuilt Volkswagen Jetta, Golf, GTI, Scirocco, Rabbit and Cabriolet 5 speed transmissions $895 exchange.
Guaranteed for 1 year, unlimited mileage in that time period.
All rebuilt units receive the following new parts :
Ring gear carrier bolt kit installed to replace rivets which often fail
Two new timken ring gear carrier bearings
Two new timken pinion shaft bearings
New gaskets and seals
All syncronizer rings replaced
New main shaft bearing
New throwout bearing
New factory end cap
Ring and pinion backlash set up to factory specifications
Parts inspected under magnification
Head technician has 35 years experience rebuilding manual transmissions.
Check out our website at www.mpgauto.com for more photos and details.
Some models of transmissions are rebuilt in stock. Any special requests regarding custom ratios will take a day or two to have ready.
Delivery available.
Open Monday through Saturday 8:00 A.M. to 7:00 P.M.
Call to discuss details or any special needs you may have. I have gear ratio charts and RPM changes for all of the possibilities that are available.
1-360-675-3939
Dave
www.mpgauto.com |
