Posted: Wed Dec 03, 2008 5:59 pm Post subject: GO BIG or go home!!! |
Dude, if you are gonna go to D/P heads and are doin' new barrels, you may as well get the work done to your case (if its any good).
If it aint a dual relief case, start looking for one and make sure its workable. There is no logic in spending money on something that will have to be done over in a matter of time. I would recomend goin' with a small stroker (76mm) which would need very little case work if any and maybe a 90.5mm bore, which would give you a displacement of 1955 I believe. I had one of these with a VZ-35 cam, a mildly ported big valve head, some clearanced and balanced stock rods ( by RIMCO),a 12lb. flywheel, 48 IDA's, man did that thing scream. I could get that thing up to 10,000 RPM and it would still be begging for more, never went past 10,500, I was afraid of blowing it up. Anyway, just thought that I could shed some light on the subject. GOOD LUCK on your mission!!! _________________ '62 Turbo Drag Bug
'65 Street Custom Bug |
