Posted: Sat Jan 19, 2008 12:43 pm Post subject: Winter work |
Thought I'd throw some pics up of what I've been up to.
Before cutting:
After:
Hoping to have this thing ready to install in the next month, need to figure out oil lines etc.
Posted: Sat Jan 19, 2008 7:05 pm Post subject: |
Nice, so how long before you are up and running?
What size is that motor? |
Posted: Sat Jan 19, 2008 9:47 pm Post subject: |
dssbk wrote: | Nice, so how long before you are up and running?
In my head, I should be a LOT farther along than I am. Being that life is getting in the way of this "hobby" I'm going to give myself 2 months to have it running. I'm not doing anymore bodywork than what I've done so far for this year though. (Still might shoot it flat black so it doesn't look as "ass" as it does now)
Engine is 2276, was going to do a 2332 but ran into problems with crank supplier, then rod supplier with the chev journals etc. So I kinda settled for the shorter stroke. I guess it's not really "settling" it'll still make good power.
Specs:
2276 9.2 CR
5.5 CB H Beam Rods
82mm Scat Nitrided Forged Crank, wedge mated, Type 4 center bearing
Norris Cam & lifters, 292 Duration, 538 total lift
1.25 ratio rockers (easier on the valve train)
Steve Timms Stage 2 heads 42x37
Mahle 94mm pistons
44 IDF's
Gene Berg 1 5/8 Merged Heater Box system |
Posted: Sat Jan 19, 2008 11:08 pm Post subject: |
Where did you get your wedge mating done? |
Posted: Sun Jan 20, 2008 8:03 am Post subject: |
I went through Scat on the Crank/Flywheel. I'm sure they farm it out, not sure to who. |
Mr Bs Bug N Buggy
Joined: 06 Aug 2007 Posts: 104 Location: Spokane Valley, Wa
Posted: Sun Jan 20, 2008 9:46 pm Post subject: |
Boy........that thing sits HIGH in the rear, we should be able to do some off road runs together......  _________________ Mr. B
Viper Dune Buggy
and some parts !!!
Dune Buggies are unequaled in "smiles per mile" |
