Posted: Sun Oct 02, 2016 2:50 am Post subject: |
Here is an updated pic...
 _________________ Jeff Rogers
9.35 @ 145 |
Posted: Sun Oct 02, 2016 3:01 am Post subject: |
Here is a link to a YouTube video of my first (and only so far) run down the quarter mile with the turbo. The clutch is slipping very badly (Almost the entire run!) but it still manages a 10.35 @ 128mph. Once I upgrade the clutch and make some safety additions too, it should be a beast!
https://www.youtube.com/watch?v=qWOAYTmvLvg
9.35 @ 145 |
Posted: Sun Oct 02, 2016 4:27 pm Post subject: Bad Bug Two now with turbo! :) |
Really getting serious! On the dyno pull what was max RPM? You going to a multi disc clutch or just a heavier pressure plate? _________________ TROY
Posted: Mon Oct 03, 2016 6:30 pm Post subject: Re: Bad Bug Two now with turbo! :) |
Troy Hobbs wrote: | Really getting serious! On the dyno pull what was max RPM? You going to a multi disc clutch or just a heavier pressure plate? |
On the dyno, only 7,300rpms. The things is such a beast, it sounds like more! All of the parts should handle 9,000rpms, but I shouldn't have to rev it that high though.
Once I crank the boost up, I am thinking it will make around 600hp to the rear tires.
It should be able to hold with just going to a black magic clutch with my current pressure plate as the four puck was pretty worn. Just thought I could get it to hold for this one last race, but was wrong! However, I may go with a twin disc Rev6 clutch from Ron Lummus.
I am hoping to run high 9's with the boost turned down and then into the 8's when I step it up! _________________ Jeff Rogers
9.35 @ 145 |
