Joined: 13 Oct 2009 Posts: 185 Location: Spokane 5-mile
Posted: Mon Nov 03, 2014 5:55 pm Post subject: Snap-on / Blue Point Plasma cutter--220v |
Blue Point Plasma 230 50 Amp Plasma Cutter 220 volt single phase
Like new condition. Works great!!
Comes with air pressure regulator. 20 foot torch. Extra consumables.
Ideal for heavy gauge cutting of ferrous and non-ferrous metals like aluminum, stainless and carbon steels. Severs up to 3/4" material thickness. Uses high frequency ARC starting to make jobs easier. Features dual power output--50 amp for cutting thicker metals and 30 amp for cutting thinner sheet metal. Uses clean, dry compressed air for both cutting and cooling. No need for refilling compressed gas cylinders during the job. Air pressure regulator provides an accurate adjustment of working air pressure for the best cut. Fan cooled. Includes complete 18 ft. torch assembly, ground cable and clamp.
Comes with extra consumables
Product Specifications
Stock # PLASMA230
Name Plasma Cutter, Heavy Duty
Price** $3,641.74
Brand Blue Point
Primary Input, V 220V, Single Phase
Primary Amps 46
Output Amps 30 and 50
Duty Cycle 100% - 40%
Gas Supply Compressed Air - 70 PSI (6 CFM)
Torch Lead Length 18'
Ground Cable Length 18'
Power Cord Length 6'
Dimensions 32" H x 20" W x 24" D
Weight 137 lbs.
$900 obo
possible trade.
Call, Email, or best TXT
Duke
5092798137 |
