Posted: Sat Apr 19, 2014 12:26 pm Post subject: 1835 longblock |
Rebuilt 1835 dual port longblock. New 20/20 counterweighted crank, rebuilt rods, 8 dowel flywheel, New Pistons and cylinders, windage pushrod tubes, swivel foot adjusters, solid shim rockers. 041 heads with new valves, valve job, and flycut.
The only used parts are the CB Performance cam, and CB oil filter pump, both in perfect condition.
Will need dual carbs to run well.
$900
Can provide the tin for your application if needed. |
