TROY WALTERS
Posted: Tue Nov 21, 2006 8:50 pm Post subject: CHANGING FROM BALL JOINT BULK HEAD TO LINK PIN BULK HEAD |
JUST A QUICK HI.
IM TROY WALTERS AND IM IN NEED OF SOME INFO ABOUT CHANGING THE BULKE HEAD ON MY 1973 BUG TO LINKE PIN im building what i hope will be a bad baja bug not a wenne bug but a fire breathing big tired hi jumping one. and i have been told to use link pin beam like a warrior that can handle stress but thay only make it in link pin so im in need of some body that knows vw to weld on the new bulk head or any othere ideas? thanks.
also is the club meeting still on dec 6 at 7.30 i would like to come and find out about member ship. |
Posted: Sun Nov 26, 2006 2:44 pm Post subject: |
Hello, no need to shout
If you are serious about a dune jumping baja I would go with a tube frame and custom modified coilover suspension, like that seen on sand rails |
TROY WALTERS
Posted: Sun Nov 26, 2006 2:54 pm Post subject: |
THANKS for the tip.
but is there some where i can buy . or some one in the spokane area that can build the tub frame |
Posted: Tue Nov 28, 2006 10:40 am Post subject: CHANGING FROM BALL JOINT BULK HEAD TO LINK PIN BULK HEAD |
Joe at J&B Welding 928-0701 can build you a tube chassis . Yes club meeting is on the 6th , starts at 7pm . TROY |
