Having major shifting problems
tdamm
PostPosted: Sun Jul 01, 2012 11:21 am    Post subject: Having major shifting problems Reply with quote
I've been having trouble shifting directly forward to find 1st. I have to search and find it almost at the 3rd position. Also when shifting to 2nd, I get reverse. This is with out pushing down on the stick. I've checked the stop plate and spent hours repositioning both it and the shifter with no results. So I'm thinking it must be internal. Anybody have any thoughts on this? Thanks!
PostPosted: Mon Jul 02, 2012 10:15 am    Post subject: Reply with quote
Have you replace the shifter bushing and coupler? Is there a lot of slop in the shifter when it is in gear?
tdamm
PostPosted: Mon Jul 02, 2012 5:08 pm    Post subject: Reply with quote
Yes, I've done all that. I'm thinking its internal like the hockey stick.
PostPosted: Mon Jul 02, 2012 5:44 pm    Post subject: Reply with quote
Take the shifter out, disconnect the coupler, slide the shift tube forward and you should be able to find out if it is the hokey stick or not.
tdamm
PostPosted: Fri Jul 06, 2012 1:16 pm    Post subject: Reply with quote
Turns out that the shift rod length adjustment nut got turned enough to throw everything out of wack. It wasn't allowing the shift cup to be centered correctly. Got it adjusted and now shifts like butter. Thanks for your reply.
Sam Cates
PostPosted: Thu Jul 26, 2012 3:46 pm    Post subject: Reply with quote
Okay, so I have read everything here, but don't know where to start. Suddenly I have been having a horrible time trying to find gears. When I go for 2nd, it shoots for 4th, when I go for 3rd, it shoots for 1st...and there is a HELL of a lot of slop in the shifter in and out of gear. So, where do I start, and where do I get parts?
tdamm
PostPosted: Thu Jul 26, 2012 4:57 pm    Post subject: shift problems Reply with quote
I'll start with the basics. Are the two bolts holding the base of the shifter tightened down snugly? Move the shifter up and back, side to side and watch to see if the base is moving. Is the base sitting on carpet?
Sam Cates
PostPosted: Thu Jul 26, 2012 5:21 pm    Post subject: Reply with quote
No carpet, bolts are very tight.
tdamm
PostPosted: Thu Jul 26, 2012 6:59 pm    Post subject: Reply with quote
Have you looked at the shift rod coupler where the shift rod and transaxle meet. Under the cover by backseat? If this is loose it would cause what you've described.
Sam Cates
PostPosted: Thu Jul 26, 2012 8:11 pm    Post subject: Reply with quote
Haven't checked that yet, will tomorrow after work.
