quevag
Posted: Wed Feb 15, 2012 12:18 am Post subject: DIY:check your car more info |
Found it on the web.Share you the good way to ask more info for your car. The way is to buy a KKL interface(cable) and search on filecrop or somewhere on google for VCDS Light software(not sure if it is free) and I think this is the cheapest way.
But you should care that it should connect to the computer.The tool I suggest by link can be used as an vag tool,other kinds cars may also be found the same function tools.
Good luck!  _________________ don't worry!be happy. |
