Split Bus Spring Plates ***Found***
ekimikem
PostPosted: Mon Oct 25, 2010 9:32 am    Post subject: Split Bus Spring Plates ***Found*** Reply with quote
Looking for a pair of split bus spring plates for my 67 bus.
PostPosted: Mon Nov 15, 2010 10:21 pm    Post subject: Reply with quote
Mike, I have a set if you need them still.
ekimikem
PostPosted: Tue Nov 16, 2010 5:15 pm    Post subject: Reply with quote
I picked up a set from Eric but they're pretty crusty. I was going to swap them out with the plates on the pink bus if nothing better came along but I'd be interested if you have something that would save me the trouble. If yours are in better shape I will give these back to Eric.
Let me know what you'd like to get for them or if there is anything you are looking for in terms of trades.
PostPosted: Tue Nov 16, 2010 5:29 pm    Post subject: Reply with quote
Actually, I think I owe you a pair anyway. You gave me some a few years back when we were both getting ready to do some suspension work, but I never used them. I will find a good pair in my pile. I know I have at least two pair in there right now.
ekimikem
PostPosted: Tue Nov 16, 2010 7:25 pm    Post subject: Reply with quote
I should be in the neighborhood Thursday or Friday if you're going to be around.
PostPosted: Tue Nov 16, 2010 7:28 pm    Post subject: Reply with quote
Can't say for sure as we are finishing up at Mitch's tomorrow. But one window did not make it in the first order so we have to install it on Friday morning. I may be around Thursday afternoon or Friday afternoon. Give me a call ahead of time.
PostPosted: Mon Nov 22, 2010 2:05 pm    Post subject: Reply with quote
Dug out a set for you. They still have the torsion bars stuck in them. I think a press may be required. The other set I had are at Eric's awaiting modification.
They are sitting on a crate under the Spruce tree in the driveway. If you make it into town and I'm not home, grab 'em.
