Joined: 13 Oct 2009 Posts: 185 Location: Spokane 5-mile
Posted: Sat Dec 11, 2010 1:37 pm Post subject: Engine start stand |
Almost done building my start stand. I will straighten out the wiring in the next couple days. Very solid and it sure is great hearing the engine run.
Put some wheels on for ease of moving!
Removable battery/fuel tray for storage
Control Panel fitted. Now time to wire the panel and put some gauges in. |
Posted: Sat Dec 11, 2010 7:57 pm Post subject: |
I think it will roll all over the shop unless you disable the wheels somehow. |
Posted: Sat Dec 11, 2010 8:21 pm Post subject: |
Of course it will, that is why I put the wheels on it!!!!!
If you are thinking it will roll around when I am running the engine...
It works great, no problem. |
Posted: Fri Dec 17, 2010 3:50 pm Post subject: |
Little more progress on the stand.
Posted: Fri Dec 17, 2010 4:26 pm Post subject: |
Dude, I have built 100's of engines and I never bothered to build one of those. I do have a universal exhaust for engine testing if you ever need it.
Why don't you make it so it can rotate, then it can be an engine building stand. It will get a lot more use that way I would think. |
Posted: Fri Dec 17, 2010 5:42 pm Post subject: |
Having it rotate was my initial idea. Still might do it. I purchased the pipe for it. |
Joined: 04 Jun 2008 Posts: 134 Location: Springdale, WA
Posted: Sat Dec 18, 2010 9:29 am Post subject: |
Nice job I like it! _________________ 60 11 window
2008 Rabbit |
Posted: Sat Dec 18, 2010 1:53 pm Post subject: |
Thanks man. Like everything, it went from simple to not so simple. |
