ab7oh
Posted: Fri Jul 02, 2010 10:38 am Post subject: How do you remove a 1969 beetle inside door handle |
How do you remove a 1969 beetle inside door handle so you can remove the door panel? _________________ Richard
1969 Bug Auto Stick
1982 Rabbit Convertible |
Posted: Fri Jul 02, 2010 11:48 am Post subject: |
For the window crank there is a pin you have to drive out. The door opener should be straight forward for you if you get the plastic piece off. Use a small screwdriver. There should be a bolt under the plastic piece to remove the pull. |
Posted: Fri Jul 02, 2010 11:50 am Post subject: |
pull the trigger of the door handle towards you, take a flat head screw driver and and pry out on the flat tab of the little black insert (seen below)
http://www.thesamba.com/vw/classifieds/detail.php?id=758894
the part on the bottom, once you remove this little shield it will expose a small phillips head.
Good luck |
ab7oh
Posted: Fri Jul 02, 2010 1:37 pm Post subject: Door handle removal |
Thank You, I got them off. The help here is outstanding.
Richard
1969 Beetle Auto Stick 1600 _________________ Richard
1969 Bug Auto Stick
Posted: Fri Jul 02, 2010 1:42 pm Post subject: |
Well, I dont know about Spro...
But I charge by the six pack!
Nah, just kidding, hope it was some help and it gets you rolling again, go check out the breakfast sunday morning at cheap shots, there will be more good advice there! |
Posted: Sat Jul 03, 2010 6:58 am Post subject: How do you remove a 1969 beetle inside door handle |
For other reading this (OP already figured it out) 68 and newer window winders are held on with a screw under the plastic handle cover (which pops off at the big end) _________________ TROY
