Motelcambodia
Joined: 14 Sep 2009 Posts: 34 Location: Idaho/Cambodia
Posted: Fri Apr 02, 2010 9:03 am Post subject: Wide 5 Baja wheels |
I'm looking for some wide 5 Baja bug type wheels
I'm going to need a set of narrow front first, steel spoked painted type are fine. The solid look Centerline or centerline look a like are OK too
I don't need the fancy aluminum type wheels as this is a real Baja bug not a street show Baja bug.
Brian _________________ Work In Idaho Live in cambodia |
Posted: Fri Jun 25, 2010 10:03 am Post subject: |
I have a set of four steel baja wheels I will be bringing to the swap this weekend. They are four lug, but they come with a complete set of 4-5 lug adapters. The front tires are excellent, the rear's hold air but are mismatched and should be replaced. Selling cheap, too. |
mikeyj007
Posted: Sun Jul 18, 2010 7:33 am Post subject: |
If you're still looking I know a guy in Rathdrum that I bought my Thing from that has 2 15x7 rims and 2 15x8 rims. One of the 15x8s was bent
just enough that it couldn't be balanced. Should be ok for off road use and they look pretty good.
Motelcambodia
Posted: Mon Jul 19, 2010 8:56 am Post subject: |
Im looking for white spoke wide 5 or centerline or look a likes.
Im in no hurry to find em but when I do I will put my link pin front end on my baja .
thanks guys
brian _________________ Work In Idaho Live in cambodia |
Posted: Mon Jul 19, 2010 9:05 am Post subject: |
I have one Jackman front wheel that is wide five. It has a dented bead but could be easily fixed with some heat and a hammer. |
Motelcambodia
Posted: Mon Jul 19, 2010 9:14 am Post subject: |
sandals wrote: | I have one Jackman front wheel that is wide five. It has a dented bead but could be easily fixed with some heat and a hammer. |
whats a jack man wheel?
208 771 3702 I will not have internet the rest of the day today
Posted: Mon Jul 19, 2010 10:14 am Post subject: |
Motelcambodia wrote: | sandals wrote: | I have one Jackman front wheel that is wide five. It has a dented bead but could be easily fixed with some heat and a hammer. |
brian |
http://www.thesamba.com/vw/forum/album_page.php?pic_id=664052
Like this, only it's a 4.5 inch wide front wheel that isn't so shiny.
I'll try to call you later. |
