dave66
Posted: Tue Nov 10, 2009 2:25 pm Post subject: Door removal |
I am trying to remove the doors from my 66' and I have having some issues, pretty much I dont know what I'm doing. At first I thought the is a cap on the top of the hinge that needs to be removed first (but I am not seeing it nor is anything popping out). I also thought the pin might need to be tapped out from the bottom (no luck there either). Is there a specific tap I need?
Any suggestions? |
Posted: Tue Nov 10, 2009 7:37 pm Post subject: |
If you open the door at look down the A pillar there are two bolts per hinge. They have a Phillips head on them. When you remove these the hinges slide out. |
colxvws63
Joined: 20 Apr 2004 Posts: 35 Location: Back in the Valley
Posted: Wed Nov 11, 2009 12:54 pm Post subject: |
don't forget the third bolt under the plastic cover ! _________________ Nothing like the feeling of towing your new car home |
Posted: Wed Nov 11, 2009 3:11 pm Post subject: |
That could make for a fun time! Sorry I forgot it. |
Posted: Wed Nov 11, 2009 4:59 pm Post subject: |
You also need an impact driver, you will strip them out with a normal screwdriver, don't even try. |
dave66
Posted: Wed Nov 11, 2009 9:34 pm Post subject: thanks |
I was thinking I just needed to pop the pins out and remove the doors that way, however, just removing the screws makes thing much easier. |
