New here
Goto page Previous  1, 2
PostPosted: Wed Aug 24, 2011 10:34 pm    Post subject: Reply with quote
Its getting there......
PostPosted: Sun Aug 28, 2011 6:54 pm    Post subject: Reply with quote
Had to swap out the air cleaners so they would clear.
Here are the final build specs;
87 mm Pistons & cylinders
Scat C20 Cam
S&S 1 1/2" Merged Header
Phatboy muffler
VW 040 Heads W/ Highrev SGL springs, 39x32
Aluminum Pushrods & stock tubes
Silverlites Bearings
Scat straight cut Cam Gear
VW Rods
Stock VW 1:1-1 Rockers on Hardened solid shafts w/ porsche style adjusters
Empi oil filter mount & hangar
VW Stock Forged Crank, .010/.010
13 lbs Lightened Fly Wheel
26mm Shadeck oil pump modded for full flow
Dual 40mm Kadron Carburetors
AS21 Case prepped by RIMCO
8mm Studs w/case savers and chromoly black hardware
Berg style Breather
Aluminum oil pump cover for full flow
8.42 Compresion Ratio
It is running great and a blast to drive now. Big props and THANKS go to Noah here in Las Vegas!!!!!!!!!!!!!!!!
Got my Tach installed today
PostPosted: Mon Oct 03, 2011 4:20 am    Post subject: Reply with quote
Picked it up from being painted again! Then I dropped the engine, swaaped out the trans-axle, put the engine back in, put the interior back in, washed it up, and then went for a cruise.
PostPosted: Mon Oct 03, 2011 10:10 pm    Post subject: Reply with quote
Drive the wheels off that thing before you leave, cause you won't want to drive it up here in the snow with all that new shiny stuff!! Laughing
PostPosted: Tue Oct 04, 2011 6:32 pm    Post subject: Reply with quote
Great looking Bug!!!!! Cool
68 beetle
PostPosted: Fri Oct 14, 2011 2:30 pm    Post subject: Im new too Reply with quote
Ive got a 68 bug that was my first car 12 years ago and has been hidden in my parents garage for the last 8 years. The 1776cc I put in it back then is gonna need a little tlc for sure, it runs but not like it used to. I am planning on a full resto-custom, and am wanting to know if anybody knows where to get parts. Im over in Post Falls ID, and have only been here for a couple years. I knew where to go in seattle but have no clue where to start here. If any of you fellow VW lovers could suggest some good parts houses That would be sweet. Ill post some pictures of what she looks like now soon, and hope to post pictures throughout the entire build. By the way thats a sweet bug.
68 beetle puttin it back together.
PostPosted: Fri Oct 14, 2011 2:33 pm    Post subject: Reply with quote
So my 1641 is having a oil leak after two rear main seal installs so we are getting another engine ready to put in. My friend who I bought/built this engine with is trying to finish up a 1914 to install next weekend!
PostPosted: Sat Oct 15, 2011 2:57 pm    Post subject: New here Reply with quote
Make sure:
seal is bottomed all the way in the case
the snout of the flywheel is polished
the o-ring isn't pinched
you don't have excessive end play (beat thrust or wrong shim stack)
PostPosted: Sat Oct 15, 2011 4:04 pm    Post subject: Reply with quote
We checked it all upon assembly and replaced the seal and o-ring when I replaced my transmision. So we are both at a loss for the moment. Not too woried, because next weekend I will have a 1914 to put into the car and he is taking the 1641.
PostPosted: Tue Nov 01, 2011 6:27 pm    Post subject: Reply with quote
Well the 1641 had a very persistant leak that Noah and I could not seem to figure out. So we talked and talked and decided to pull it out for further investigation and I got a great running 1914 in its place, for a small fee. Thanks Noah!!!!!!!!!!!!
Heads opened up for the build
On the stand partialy assembled
Aint it prety.....balanced to match the crank.
Ready for its new home
All tucked in and ready to go!
berryna
PostPosted: Wed Dec 28, 2011 7:15 pm    Post subject: Reply with quote
Very nice ride indeed. Have a safe trip and welcome to the Northwest.
ugg boots
buy ugg boots
cambridge satchel
PostPosted: Thu Dec 29, 2011 2:35 pm    Post subject: Reply with quote
I saw your car today, well the lights and bumper anyway, over by the "lemon lot" on base.
PostPosted: Sun Sep 23, 2012 10:32 am    Post subject: Reply with quote
Well it has been a while since I updated this so here we go. I added a third brake light, CB Performance Ball joint dropped spindle disc brake package with a new master cylinder and resevoir, narrowed my beam 3", and added some new lower tins I fabbed up, as well as a new breastplate that I filled in the holes on.
PostPosted: Sun Sep 23, 2012 10:44 am    Post subject: Reply with quote
How it sat for the Volksfest 2012 show in Moxee, WA.
Page 2 of 2
